What is the difference between A and B? The direction of travel? When will we find out about the 'one weird trick' on run #7?
I'm with dirtydave, having different persons driving and timing would eliminate a source of bias.
You are correct freebeard, the difference in A and B is the direction of travel. I will comment on the 7th run in a new post. My brother did the data keeping and timing
