Old 05-31-2015, 04:12 PM   #26 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 2009Toyotoad View Post
The more I read about Coroplast the less I'm inclined to use it under a car. Its a diverse group of manufacturers and heat tolerance seems to vary quite a bit from one manufacturer to another. UV resistence is another concern with the product.
I'm also kinda skeptical about coroplast for underbody pans. I'd rather use even marine-grade plywood instead. You might be aware that it's used even in off-road racing vehicles since it can stand some impacts.
