Old 05-31-2015, 10:40 PM   #4 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I don't want to mod the frame on this. The bulk of the frame is just an aluminum box that holds the batteries, anyways.
However, I did think that a good place to start was just to take the seat off. Depending on how you measure it, the seat is over four inches thick.
I took the seat off and just sat on the battery box. It sort of turns into a recumbent just by doing that. I set up my camera on a tripod and a timer and scaled that photo to the same as a previous one I took, so I could see how tall I was in the standard position versus with the seat removed.
As I was playing with these images, I just started sketching what might be a fairing over the top of it. By the time I was done, I ended up making an animation.
Hope it loads right!
1. Cycle with regular upright sitting position. (Trunk was removed in this photo, shows attachment points for a custom tail.)
2. Seat removed (becomes sort of a recumbent position. Trunk is back in place in this photo.)
3. Imaginary nose-cone added.
4. Imaginary tail added.
Removing the seat sure feels like it drops me a lot. It seems to put my shoulders solidly BELOW the top of the windshield, but my line of sight is still over the top of the windshield. I rode around the block like this. It's real easy for me to tuck all the way behind the windshield, and air pushing on my shoulders seemed like a lot less. (Even though I was just doing a little low speed through my neighborhood. Maybe tomorrow, I can put some foam under my butt and try something a little faster.)
Down that low, the handlebars are just a little far away. I'm not sure if I can adjust them or not. Adding a piece of plywood/foam/cover over the battery box would raise me up a tad, maybe just enough to make reaching the handlebars better.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 2 Users Say Thank You to bennelson For This Useful Post:
BamZipPow (06-01-2015), user removed (06-01-2015)
