^^^ also note: Oxygen Free Copper (OFC) VS Copper Clad Aluminum (CCA) wiring. If you use CCA instead of OFC, you need to increase the gauge size to compensate! I used an amp-clamp and measured all my wiring to make sure I had the right gauge (or larger).
