05-23-2015, 11:12 PM
#11 (permalink)
Cyborg ECU
Originally Posted by dirtydave
I had the same issue for a while. Got a deep cycle battery and upgraded the wires from the starter. Can key start after sitting a good 10 minutes with marker lights and turn signal on.
How did you upgrade starter wires? Larger gauge? How does it help? ... I also charge my 40ahr deep cycle battery at night. I have an on-board 25amp "smart charger"...
05-24-2015, 02:53 PM
#12 (permalink)
Not bad for a machine
yep larger gauge.
works very good.
google "big three upgrade"
06-02-2015, 02:33 PM
#13 (permalink)
Frogger - '00 Honda Insight Gas Only (unHybrid) 90 day: 68.51 mpg (US)
^^^ also note: Oxygen Free Copper (OFC) VS Copper Clad Aluminum (CCA) wiring. If you use CCA instead of OFC, you need to increase the gauge size to compensate! I used an amp-clamp and measured all my wiring to make sure I had the right gauge (or larger).
06-12-2015, 01:47 PM
#14 (permalink)
I never had an issue with the Anal Probe, but it should be said that letting the engine run for a mile to charge the battery is not going to ruin you, either. If you're having problems, just driving normally for a couple miles during the trip would be a great short-term solution before you go LED and PV.
And, please use your brake lights instead of the emergency brake. Cars have brake lights for a reason.
06-13-2015, 06:36 PM
#15 (permalink)
The PRC.
Has anyone worked out the savings vs. Costs of eoc and battery charging ?
06-15-2015, 03:59 AM
#16 (permalink)
I just drove from home to Prague ~600km one way with EOCing almost the whole way. Headlights and markers turned on, radio on, ocasionally wipers due to rain in some places I was passing by. No issues with the accumulator. It was fully charged before I started my trip though. Accu is like 6-7 years old. And a bit bigger than it's needed and suggested by the factory for my VW Polo. That was the one I had anyway so since it's still going strong I have no intentions to change it.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
06-23-2015, 01:56 PM
#17 (permalink)
Honda Head
keep in mind dropping the battery voltage constantly on a typical car battery will shorten its life. i know the mileage game is the goal but not at the expense of a 100$ battery(money, pollution/inconvenience). i would say from my own guesstimate a battery only needs about 30 mins of running time to FULLY charge, from like a dead/jumpstart situation. that being said, i gave up shutting my engine off at stops, unless i know they are lengthy, like a train crossing.
alternatively, EOC/no idling as much as you want in the day time, conservatively or lights off at night only. and if you must, just stop doing it for the last 15-20 mins of your drive home before you park, to let the battery recover
06-23-2015, 08:15 PM
#18 (permalink)
I'll save around $500 in my first year of EOC/ idle stop with EMMA. If the cost of a product is roughly indicative of how much pollution results from it's manufacture (obviously you can't apply this theory to every product), then a $100 battery is a small price to pay. I'd guess the battery will go on another two years at least, when it will be replaced by my 5 year OEM warranty. Even in normal use, modern car batteries seem unlikely to make it much past 3 years.
There's also inconvenience in making six extra fuel stops a year.
YMMV
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
06-23-2015, 09:25 PM
#19 (permalink)
Hydrogen > EV
06-24-2015, 03:31 PM
#20 (permalink)
The PRC.
I've never had to buy a battery so I don't know the costs there. I did have a bad alternator which nearly killed a battery but that car was sold with the same unit in it and starting first thing every morning.
