Old 06-03-2015, 10:47 AM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
The aero cap is probably where you'll get your biggest efficiency bang for the buck if you spend a lot of time at 55 mph. I'd consider starting there.
Or...
I think the tapered bed and the chopped top probably helped. But my gut says the front taper that exposed the front wheels is worse than stock in that area.
From: http://ecomodder.com/forum/showthrea...tml#post455297
ID:	17871   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (06-04-2015), Sneakybassturd69 (06-03-2015)
