Old 06-10-2015, 12:56 AM   #3 (permalink)
iceyinferno
Dino - '93 Honda Civic DX
90 day: 43.65 mpg (US)
White Shadow - '15 Toyota Prius C Two
90 day: 50.69 mpg (US)
I'm not familiar with the wet test, I'll check that out. I went ahead and swapped the injectors over from the other motor and got the same symptoms. I then disconnected the o2 sensor and drove it once more...everything is fine without lean burn mode. So I think I have a temporary fix, so long as leaving the o2 disconnected won't cause long term negative effects?!?
