Old 06-10-2015, 12:45 PM   #12 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
You guys are projecting too much into the category of "truck." This rig, this little Hilux, doesn't need a V8 or even really a V6. The stock base engine in an '86 Hilux was a 2.4l straight 4 generating a whopping 102 horsepower. 116 for fuel injected.
You can get that kind of output from a smaller engine now. Finding sufficient power in a small enough package to fit in the engine bay of a Toyota Truck should be a snap - that engine room is pretty roomy, I know from experience. A 2.0 straight four from the base Camry of the late 80s provides approximately the same power.
The important thing will be finding a way to mesh drivetrain with suspension. The Hilux' arrangement is control arms and torsion bars and if I recall correctly there isn't any kind of provision for front drive components unless you look at the 4WD models.
