Old 06-15-2015, 11:59 AM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Sven7 View Post
If those are factory-built wheels, be sure to give all the spokes a half-turn (or more, if it's loose) before you start riding! I just pulled apart some old Varsity wheels this past week and the nipples were literally finger tight. Very scary. I laced in a front drum hub...
12 miles is quite a distance. I hope you have a grocery store closer to home! If you're looking to carry things, head to a bike shop and try out some rear panniers for that rack. You might be able to find a pair that doesn't hit your heels, and most will fold up and out of the air when not in use. I prefer putting things on a front rack/panniers, but your front end is probably pretty heavy already with that motor.
Thanks. I got the motor pre-laced into the wheel. I figured it was safer that way because I had never done it. If I ever build another, I'll learn to lace it myself. There actualy is a panier in the photo in post #1... it is hard to see because it is on the far side of the rack... "black and red" is its color. I have had it a few years. And it bumps my heel sometimes! But it's an easy adjustment... my 12 mile commute is to work... fortunately the supermarkets and autoparts stores and such are Ll just a mile or two. But this bike is meant to make it easy to replace my car on lots of commute days. That's partly in case of a car breakdown too.
Make my first trip to work today on the bike.... !
