Old 06-20-2015, 12:58 AM   #429 (permalink)
GreenHornet
GreenHornet's Avatar
This car is going to be super light by the time you get done adding all the Triumph aluminum alloy parts. It is pretty easy actually to take out a few hundred pounds from these cars. There are so many Aluminum alloy racing parts for these cars which makes it really convenient for us ecomodders looking to shave weight. I bet the car will be under 900 lbs by the time you are all done with it if it is not all ready. If my calculations are right between the exhaust and the bellhousing you just dropped 46 lbs. That is an Awesome job with weight reduction and will definitely make a difference at next years GGP.
Keep up the excellent work my friend can't wait to see more
GH..
