damn I missed that post Sven7 I think a tc switch would be sweet and I think ill need it a bit higher on the rear I tried the template but I think I messed it up or the camera angle was wrong...
and its not too big 25.5 frontal area.
as large as possible for a "compact"
a big larger then the cavalier
a big smaller then the lumina
all share the same engine / transmission
I have seen 2 or 3 in the past few months. all with bad paint
the scangauge is not calibrated so I'm sure its off a bit what direction? ??
going to fill er` up soon
oh and I got the coolant thermostat and DRL all fixed now to keep the radio on when the key is off and aeromod it on the 24th
