Thread: Mustang?
Old 06-21-2015, 08:45 AM   #23 (permalink)
oldschooleco
I used an external source for a while, but I think it's easier to make an album on your User Control Panel page.
Has anyone mentioned ignition? Points-and-condenser are only in tune when they are set and then they begin to drift out. A drop-in replacement like the Perlux Ignitor helps. The Magna-Spark distributor I have is for four cylinders but uses a Ford cap and rotor. It is available in 3 or 4 levels, from a 'stock' red coil, to MSD compatible, to fully digital without a rotor.
So that's like five or six possible levels, and there are ignitions that use a coil for every 2 cylinders.
I plan on using a duraspark II factory ford electronic ignition, for reliability simplicity, performance, and economy.
The Following User Says Thank You to oldschooleco For This Useful Post:
freebeard (06-21-2015)
