Old 06-22-2015, 01:25 AM   #85 (permalink)
serialk11r
Originally Posted by deejaaa View Post
looks good to me also. there are other 'colors' to choose from and focal point is where I would want it.
did you mount the other yet?
can you get some distance shots?
Yea I'll post a picture sometime. Too lazy to go move the car and take a picture right now. Now that I've driven with it a little, I think the focal point is a tad low, I'm going to turn the adjustment screws to point the beam a little higher. Right now the road itself is lit up very well but it's hard to see in the distance and to the sides.
serialk11r -- Now that's a nice cut-off. What is the depth of the housing/reflector compared to the H-4?
No idea, it's a standard H11 housing that used to have a standard OEM H11 bulb. I think the light output is a little lacking compared to some earlier posters' H4s because projectors basically waste half the light output with the cutoff plate, if I remember correctly. Halogens do better since the filament is small and doesn't block as much light reflected off the plate. Definitely do not buy the "40W" kits for this application unless it's for foglights or DRLs.
