Old 06-22-2015, 12:12 PM   #251 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by California98Civic View Post
Checked your fuel log and I am am reminded of your older build, that 3 stage vtec Civic you modded. You edited the ECU to get "ultra lean burn" at certain freeway cruise RPMs and edited other parameters to produce more power.
What is your ultra lean burn range now? I remember you were using a CX/VX transmission IIRC to keep RPMs down. But this car has pretty short gearing, no?
I miss the Del Sol with Neptune on a P28 ecu. The Civic before that was running a Haltech stand alone and my sons Civic was running a P28 with CROME.
My Talon lean burn range is 30 to 35:1 light load freeway, 20 to 22:1 mid load, and now 14.5 to 15.5 low boost 13 psi. and 11.8 to 12.8:1 high boost 14psi. to 50 psi.
My last Del Sol lean burn numbers were close to the same at light load freeway but every other load I was running around 11.8 to 12.8:1.
The Talon gearing is very low compared to the Del Sol. At freeway 65 to 70 mph I'm at 3000 rpm to 3100 rpm.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
California98Civic (06-22-2015), deanznz (11-04-2023)
