Originally Posted by oldschooleco
Im going to try to run between 9.5-10:1(until i build my turbo 351). and there is no OBD2 and it will be carbed.Im not trying to put lipstick on a pig because I'm not expecting what you guys get for mileage 35 and up lol. Ill be tickled to death with low to mid 20s at 65mph which isn't to much to ask from a light weight slippery body with some tricks done to it,Thank you all
I know this is your build, but even obd1 would be better that carb. And you're leaving a lot of power on the table by not going higher compression.
