Getting away from the AC project I have been busy working on taking out the flip up headlights along with all its components. With both lights out along with the pulley, metal brackets, hinges, and Headlight electric motor I was able to remove 40lbs of weight.
My plan is to eliminate the flip up lights and replace it with LED fixed lighting. My main reasons for this are:
1. More complex have more parts to fail
2. More parts = more weight
3. Eliminating the flip ups creates usable space for other components
4. Less efficient uses more energy to operate
5. Less aerodynamic when operating at night
I will not be putting the lights in the current housing location. The housing areas will be glassed over and lighting relocated to the front wear a modified front bumper and grill will house them.
The LED lights will be simple 30W units that emit around 2,500 lumens. I will be using a dial dimmer to control the light output of the units.
