Originally Posted by ksa8907
I know this is your build, but even obd1 would be better that carb. And you're leaving a lot of power on the table by not going higher compression.
IMO for street, lower compression with high boost is better than high compression with low boost. While under boost, you have your power, while not under boost, you get decent mileage.
