Old 06-23-2015, 07:22 AM   #131 (permalink)
Trinost
Trinost's Avatar
Baltothewolf I looked at your link:
Q1
What type of AWG is the black wire that you use for the kill switch feeding through the fender? (Cannot see it on the spool)
Q2
The HOT side of the injector plug goes into port #30 on the relay. You must create a jumper from the hot side to pin #85
How do I know which side is hot?
Q3
What exactly is a jumper?
-- Correct me if wrong, It looks like a jumper is the hot wire (guessing hot from red insulation crimp) tied with another wire allowing the hot to go to two different pins?--
Thanks
Toaster 01 Insight MT(A/C) 163k
Mods:
Installed 3 button nob w/flame icon
Future Mods:
*Install Kill switch to 3 button nob
*Replace missing car front aero panel & inner plastic fenders
*Radio antenna w/stub & radio w/usb port radio
*Security system w/key fob+tinting
*Minor body work/misplaced clips?
*Buff/Replace headlights w/Sylvania 9003
*Rebuild my original pack w/good used sticks (need stick providers plz pm)
Pm any help/tips/suggestions
