Old 06-25-2015, 01:24 AM   #121 (permalink)
oil pan 4
While driving and keeping the engine under load the operating temperature doesn't seem to change a lot.
But idling, with the heat blowing I have seen it drop from 190'F down to 160'F in little more than 10 minutes when running non turbo.
Adding the turbochargers to the cooling circuit has helped this.
Iron has lower specific heat, but is almost always black so emissive losses will be higher.
Aluminum holds more heat and the blocks are usually bare finished and some what reflective, cutting down on IR emissions.
If you have an aluminum and iron block offering for a specific engine, you can bet the iron block will come up to operating temperature faster and also cool off faster.
