Old 06-26-2015, 03:27 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Honda Fit 2007-2008 engine/trans mount/bracket locations
Originally Posted by rmay635703 View Post
... imagine the amount of time saved re-inventing the wheel if even simple photos of pencil outlines to paper were made when folks remove xmsns from engines
Could be a good thing to have a repository of here on eco modder.
I could start, the 700r4 bell and mounting is identical to the far superior NV3500 5mt (as is the 4t60)
Absolutely! And this can be a collection of more than just Prius engine stuff, but the data re: lots of cars tha such swaps might be made into. The kind of ECO car chassis we can get cheaply, good mules for a engine/trans swap.
That was part of the point of this thread. Could you edit your post just to be more specific about the makes and model? The codes are a little arcane for some of us without familiarity (yet). Thx!
As my part, a bit different from yours in that it is about mounting an engine/tranny combo into the engine bay, here is a diagram. There is a lot of crap data/photos out there for Fit engine bays and what good data there is is for the speed-performance tuners, not us:
Engine/trans mount locations for the 2007-2008 Fit 5MT with key (all from honda.com):
1. rubber assy., transmission mounting (mt)
2. rubber, rr. engine insulator (mt)
3. rubber assy., engine side mounting (mt)
4. bracket, transmission mounting
5. bracket, rr. engine mounting (mt)
6. stopper, fr. engine
7. bracket, l. fr. stopper (mt)
8. bolt, l. fr. stopper
9. bolt, flange (10x38)
10. bolt, flange (10x50)
11. bolt, flange (10x138)
12. bolt, flange (10x20)
13. bolt, flange (12x100)
14. bolt, flange (10x30)
15. bolt, flange (10x25)
16. bolt, flange (10x45)
17. bolt, flange (10x53)
18. bolt, flange (10x35)
19. nut, flange (10mm)
20. nut, flange (12mm)
21. bolt, stud (10x70)
22. washer, fr. stopper
Name:	Honda Fit 2008 Engine Mounts - manual transmission.png
Fat Charlie (06-26-2015)
