Not just air flow, you need convection. The VW Beetles can put out only a little over 200F air in the cabin vents. And that's with heavily finned aluminum OEM heat exchangers (fins on both the inside and outside of the exhaust manifolds!) with not a lot of air flow. Maybe if you had finned exhaust from the tail pipe clear onto the exhaust manifold, but that still probably wouldn't get you enough heat.
