Old 06-28-2015, 06:10 PM   #2 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Using the ignition method may cause unburnt fuel to pass along to your catalytic converter, and may reduce its lifespan. However, cutting power to the pump will result in a slower kill, because fuel rail pressure doesn't drop to zero instantly. It may take a few seconds for your engine to die, and in those seconds it will probably lean out significantly.
I'm currently using an injector kill.
EDIT: Aerodynamics seems an odd section for this question.
