Old 06-28-2015, 09:08 PM   #442 (permalink)
changzuki
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
Big Wheelin'!
GreenHornet has started a thread on his Urba Centurion and a recent post was about the size of the steering wheel:
http://ecomodder.com/forum/showthrea...tml#post483575
For those considering a Centurion build, consider a 13" steering wheel to be about the largest one you'll want in these cars. Interior room is adequate but a smaller wheel goes a long way in regards to freeing up a bit of space. Just make sure you get one that is "flat" and not "dished". The dished wheel places the wheel closer to you and that is not needed.
Depending on your seating position and your leg length, your knee may be sandwiched between the 13" wheel and the door. This comes in handy if you need a temporary wheel lock -
If you still need a bit more room or just want to complete the "go-cart" motif, an 11" wheel will be right at home. These are extremely similar to ones found on the car "arcade" units:
And for the same 50 cents you might use in the arcade game - you'll likely have more fun for a longer duration in a Centurion!
~CrazyJerry
The Following User Says Thank You to changzuki For This Useful Post:
aerohead (07-08-2015)
