Old 06-29-2015, 10:15 AM   #29 (permalink)
Daox
My thoughts:
Divert one of the engine's coolant hoses (inside the loop behind the thermostat) through a copper tube wrapped around the exhaust manifold. Add a heatercore with a fan that's wired in parallel with the radiator's fan to help with cooling once everything is warmed up.
Honda built the G1 Insight with a waterjacket on the exhaust manifold and beefed up the main radiator a bit to compensate.
That is definitely a doable idea. I guess I just don't want the aero or electrical fan load penalty of having to get rid of that heat once up to temperature.
