Old 06-29-2015, 05:30 PM   #31 (permalink)
oil pan 4
The old carbureted engines used a heat shroud around the 1 or 2 of the exhaust manifold exhaust primaries to give the carb some warm air almost immediately after startup.
This was just mostly so it would idle and not stall constantly right after a good cold startup.
The exhaust manifolds get real hot but its not very easy to get a high volume of really hot air off them.
Daox (06-30-2015)
