Originally Posted by Vekke
this first turbo is 1749V which is only good to go max 135 hp range. I will install 1749VA later to meet that 144 hp power target need.
I havent yet driven the car with this new turbo or engine. Just cruised on the yard. 1749V or 1749 VA should "wake" up around 2000 rpm.
ok your BV35 is the KKK7BorgWarner equivalent to Garret 1749V VNT15 VGT Turbo.
those power ranges came from experience, from maxpower of common chip tuners or from calculations according the characteristic map or specification of the turbo itself?
