Old 06-30-2015, 10:01 PM   #32 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Looks like all motor no capacitors
If so,then the motor will handle 12v ..
what duse the controller system look like ??
any capasitors ?
What voltage are they listed 5v 16v???
What stops the shutters from rotating past open and closed? ?
if capasitors are marked as 14.7v or higher , then plug it in add a choke cable (to activate it) and done?
if marked as 5v, then use a cell phone charger as a power supply ... ...
If the vent has make or break contacts for stops then you can just add a toggle switch and flip between positions
Dakota Digital Programmable Dual Fan Controllers PAC-2750 - Free Shipping on Orders Over $99 at Summit Racing
DAKOTA digital PART# DAK PAC 2750
This canbe used with any electronic temperature gauge including stock(as per Summit racing)
GlowShift Elite 10 Color Water Temperature Gauge
this one(complete gauge set) has programmable warning lights... instead of turning on and off lights use it to open and close the shutters, fans
in the rc( remote control) world your capacitors are the limiters run the same dc 55turn 550 with 4v through 24v (1cell lipo -6cell lipo)
