Old 07-01-2015, 10:26 PM   #260 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
After looking closely at one of my 95*F test run logs, I think I have max out this combination as far as freeway FE is concern? Around 45 mpg with the waste solvent disable has been my personal best. I was considering making a belly pan and a full grill block but now I think I'm going to call it good.
All my attention is going to be on my waste solvent system. I'm running a 50/50 mix right now and its working great in this high heat were having. In fact I did some hill-billy testing and have my lawn mower running on a 60/40 waste solvent mix at 95*F.
My next project is to build a 1 liter lean burn 13g turbo 91 Talon FWD manual 5 speed transmission. This car will have all the stock interior, with all mods built for FE only. My goal is to get around 65+ mpg.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
UltArc (07-02-2015)
