Old 07-03-2015, 09:27 AM   #10 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
XFi cam is advanced vs non-XFi
For consideration: 40 teeth on a stock 1998 Metro/Suzukiclone G10 1.0L SOCH cam sprocket = 9 degrees per tooth. Correction: effectively becomes 18 degrees per tooth due to the 2:1 ratio of cam:crank sprockets.
Also: the more efficient XFi cam is reportedly "6 degrees advanced from the stock cam, based on measurements of intake centerline," according to the resident cam guru (superf1y) at teamswift.net.
But the XFi cam lobes also have lower lift & duration.
International heart transplant: the Blackfly gets an XFi cam - MetroMPG.com
Daox (07-03-2015)
