Old 07-06-2015, 03:05 PM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Re. grille blocking: OBD-II instrumentation like a ScanGauge or equivalent would also be good for monitoring coolant temperature -- and they save the max value in the current trip data, so you will know if your cooling fan has come on (assuming you've tested the fan/temp threshold). Or you could add a LED to the fan circuit and mount it where you'll see it.
Subscribed for progress updates!
