Old 07-07-2015, 01:17 PM   #8 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Gandalph View Post
the car's built-in meter only goes up to 80 MPG. I'm going to need a meter with a higher max than that
... You know you're an ecomodder when ...
I do about as much coasting as I can in neutral with the engine on while I'm slowing down to a stop.
If you're actually trying to slow down, leaving it in gear will save a tiny bit more fuel, as the injectors go into fuel cut when you release the accelerator above a certain RPM.
Joggernot (07-07-2015)
