Old 07-07-2015, 03:05 PM   #89 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
UPDATE: air dam version 2.0
I haven't had an air dam on the Firefly/Metro since I posted this thread back in 2009. However, inspired by Tim's recent Metro lawn edging air dam thread, I just did something similar.
I've done a couple of air dams since 2009, just not to the Firefly, eg:
Here's the Firefly's version 2.0 ...
Tim used metal brackets to mount his in a very respectable one hour of tinkering time. Very quick 'n' easy, but it can have an uneven, "wavy" look to the edging, so I took a slightly different approach.
1) I trimmed a length of 1x3 wood to match the curvature (plan) of the bottom of the bumper (front face) where the lawn edging would attach. Then I attached the wood to the bumper and screwed the edging into the wood.
2) To take the waves out of the bottom of the edging, I screwed 2 layers of coroplast to the back side to make it thicker.
3) To stiffen the air dam to keep it from being pushed backward, I screwed a couple of scraps of edging between the air dam and the wood, under tension:
Each one is just touching a screw that comes through the air dam, so they're pretty stiff/secure. But not so secure that they won't give way if (when) I hit the air dam on something.
It's got 5 inches ~13 cm of clearance. A bit more than I would like, but one of these years I'll lower the car an inch or 2 and make it just right.
To finish up, I just need to dab some black paint on the screw heads to hide them a bit.
ID:	18228   Click image for larger version
ID:	18229   Click image for larger version
ID:	18230   Click image for larger version
ID:	18232   Click image for larger version
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
AndrzejM (07-07-2015), blownb310 (07-07-2015), Daox (07-07-2015), Xist (07-08-2015)
