You could use a diesel injector to meter it or use it as dual fuel in a diesel. There are some really cool dual fuel diesel-gasoline engine studies. Since diesel engines and gas engines can run beginning with the same static compression you add spark plugs to the diesel engine and use the gasoline when its most advantageous and I think they even have one injector to meter both fuels if I remember right.
