Old 07-09-2015, 03:25 PM   #4 (permalink)
kafer65
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Get after as much of the rust on the inside of the panel then see if you can get some rust converter on the places you can beyond that. One of my methods was to heat up gear oil and spray it on the backside of the effected panel. Also, mix kerosene and the wax from toilet base wax seals to make homemade rust barrier thats sticky and will endure longer.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
The Following User Says Thank You to kafer65 For This Useful Post:
AbramWagner (07-09-2015)
