Old 07-11-2015, 10:23 AM   #96 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
This is awkward for DIY's.
An automaker knows the road load and BSFC for their vehicle.If they plan to modify it,they can predict it's performance numerically.
If you had intentions to fully trick out the Focus aerodynamically at some point,there would be a practical issue of going ahead with all that,and then modify your gearing to control the BSFC.Altering the engine isn't necessarily required.Just gear-matching. So says the automakers.
The automakers gave my car the highest gearing possible from the factory, which is why I have not mentioned it Mr. Phil. Thanks for that one, Ford
Now, the sedan manual transmission I plan to swap in has very similar gearing to my auto. It will make the engine turn 75-125 rpm more at my usual speeds. What the manual does offer is the option for a custom 5th gear with an ultra-deep OD.
Here is the link to someone who did it several years ago.
I think what I was trying to say in my previous post is I have too much engine/power. Also, the powerband is too high for the best performance down on the low-end. So I have to either reduce displacement or reduce the power of the engine through shifting the powerband downward. Hence why to go with LB to make the engine more efficient below 2500 rpm, and to simulate having a less powerful engine.
I also am planning to go from 16 valve (2I, 2E) to 12 valve (1I, 2E) which in theory will reduce the total amount of power the enine can make, increased swirl in the combustion chamber and have better low-end performance. The idea is comes from the VTEC-E engine in the VXs.
Btw, the plan is still to max out the aero Mr. Phil. I'm trying to get to 0.15 Cd, remember?
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
