Old 07-13-2015, 01:30 PM   #20 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by MPGomatic View Post
Good choice! Slambo's running happy with Defenders, 10K or so and they're looking fine.
How tough was the front bearing replacement? My rear bearings were done recently, I have a pair of fronts sitting on the shelf.
I did one front bearing DIY, except for pressing the new bearing in. I took the knuckle to a machinist for that. $20 or something was what I paid. Maybe $30... I don't recall. There is a test to see if the bearing unit is failing:
http://ecomodder.com/forum/showthrea...tml#post364406
I only replaced the one indicated bad and the problem went away. The other three bearing units are OEM 1998 and still going strong! Save $$!
Hope that helps...
James
