Old 07-15-2015, 05:45 PM   #75 (permalink)
The donkey CRX
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Reply to Bluesteel "C" clips on Kammbach
Here are some pictures I took today. Hopefully they will show what you wanted to see.
The problem we had before was that the carbon fiber was so stiff it would not stay low enough on the sides and top to conform to the "template". So I made these hand made "C" clips that wrap around the rubber surround of the glass lift gate and force the kammbach to stay where I wanted it to be. They are made from some scrape .090 sheet aluminum. I created the curved "C" part by gradually bending the aluminum with our sheet metal bender at the shop. I know your brother can probably do the same with his.
Here are some pictures of how it is mounted.
Here is a picture of the kammbach up close. It has been modified quite a bit from its original purpose as a "drag racer wing" that kind of went almost straight back from the end of the roof.
Hope this shows you what you needed.
The Following 3 Users Say Thank You to The donkey CRX For This Useful Post:
AbramWagner (07-30-2015), bluesteel93 (07-15-2015), OG VX (07-16-2015)
