Old 07-15-2015, 06:55 PM   #161 (permalink)
darcane
darcane's Avatar
Originally Posted by Vman455 View Post
That's not what I said. First of all, dirty oil is not a bad thing--it gets dirty because it's holding particles, combustion byproducts, and wear material in suspension, which is what it's supposed to do. Second, no--you can't feel a difference between an engine running "dirty" oil and the same engine running "clean" oil.
Agreed. I can feel no difference.
But I still change my oil. I know my engine needs to be properly lubricated and the fresh oil keeps deposits from building up inside the engine. I do this to make sure my engine lasts as long as possible
And that is the reason I add TC-W3 to the fuel...
the same way experienced sommeliers cannot distinguish between red and white wines in blind taste tests.
You may have to explain this one a bit...
I'm no connoisseur, but I enjoy a variety of white wines. I really don't care for any of the reds I've tried, and many are completely undrinkable. I think I would have a real hard time confusing the two
The only study I could find related to this was The Color of Odors
Where 54 undergrad students failed to recognize that they were being actively deceived. They were given two glasses of wine, both the same white wine, one with food coloring, and asked to describe them. None pointed out that the "red" wine was really a white, but they did use some traditional white wine descriptors for the "red". It does mention that people could typically tell if an opaque glass of wine had a red or a white with 70% accuracy from smell alone.
The frictional properties of conventional and synthetic oils of the same weight are so close as to be indistinguishable to a person driving the car around or "feeling" the engine.
Agreed under normal operating conditions. However, at extreme cold temps, the difference in viscosity can get very noticeable, especially in the tranny/rear end.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
