I did another compression check last night. The first round was dry, all were still right at 130 psi. Then I added oil. They all came up to about 150 psi, but would go a bit higher if I cranked longer. Thats not a good sign.
This is still not completely conclusive if the timing is off I think. So, I'll be checking that tonight.
![](http://ecomodder.com/forum/attachment.php?attachmentid=18333&stc=1&d=1437078487)
