Old 07-17-2015, 02:25 AM   #268 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by California98Civic View Post
Nice pics, and I just noticed in the pic that this is an automatic transmission. Your last three tanks average 54.43 mpg and it is a turbo auto transmission street racer car. Do you have average speed data? I wish I did, but my UG speed calculation goes haywire when I use EOC.
I don't have a average speed data parameter output. I'm just going by the time and distance of the test trip. I use the same route over and over to keep everything as close as possible.
Also keep in mind I have been running waste solvent enable, so my true MPG without waste solvent is still just 42 to 45 mpg.
I don't want to miss guide anyone when the waste solvent is enable. I just don't know how to explain it other then waste solvent is dis-able or enable.
The waste solvent so far is free. At some point and time it might not be, then i will have to associate it with a cost to run my solvent recycler to generate waste solvent and add it to to true cost of the waste solvent fuel used.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 3 Users Say Thank You to pgfpro For This Useful Post:
California98Civic (07-18-2015), COcyclist (08-26-2015), deanznz (11-04-2023)
