Old 07-02-2015, 07:34 PM   #261 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by pgfpro View Post
1 liter lean burn 13g turbo
Where would you source that from? And of course I imagine you'd put a rig like that into a FWD, not AWD.
Old 07-04-2015, 01:34 AM   #262 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I'm working on a 1.0L 4G63 engine that can be utilized in my future FWD 5 speed manual transmission Talon.
I will have a full write up as I get closer.
Pressure Gradient Force
The Positive Side of the Number Line
Old 07-04-2015, 10:05 AM   #263 (permalink)
Master Novice
elhigh's Avatar
You must be moving to a short throw crank, then, or else sleeving the cylinders. That's a two liter engine according to Wikipedia - which is, of course, infallible.
I had a 4g64 in an Expo AWD I got from my grandmother a year or so before she died, it was immaculate inside but the chassis was absolutely raddled by 20 years of Minnesota winters and the engine dropped a valve after about six months of use. Too bad, I thought the level of aftermarket enthusiasm for the 4g series was pretty strong.
The Following User Says Thank You to elhigh For This Useful Post:
pgfpro (07-04-2015)
Old 07-04-2015, 11:21 AM   #264 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
sleeving down or destroking to half of the original displacement would be rather extreme(though with a head/cams intended for a 2-liter, it would probably make quite the screamer)... perhaps 2-cylinder mod?
The Following User Says Thank You to RobertISaar For This Useful Post:
pgfpro (07-04-2015)
Old 07-11-2015, 02:10 PM   #265 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Looking at getting one of these today.
This would make tuning much easier and safer for me. I will purchase a dash mount also and mount it right in front of me. I probably will go with a blue tooth remote key board also. When I'm pulled off the road and need to review data logs.
Old 07-16-2015, 10:33 PM   #266 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I hooked up the Stream 7 to my car today after I received my micro to USB Host cable and Arkon mount.
After playing with it I'm very happy with the mount and the fact its not impairing my vision. I think I will still purchase a Bluetooth key board for the
F Keys that make navigating easy on some of the ECM Link features.
The Following User Says Thank You to pgfpro For This Useful Post:
California98Civic (07-16-2015)
Old 07-16-2015, 11:30 PM   #267 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Nice pics, and I just noticed in the pic that this is an automatic transmission. Your last three tanks average 54.43 mpg and it is a turbo auto transmission street racer car. Do you have average speed data? I wish I did, but my UG speed calculation goes haywire when I use EOC.
pgfpro (07-17-2015)
Old 07-17-2015, 02:25 AM   #268 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I don't have a average speed data parameter output. I'm just going by the time and distance of the test trip. I use the same route over and over to keep everything as close as possible.
Also keep in mind I have been running waste solvent enable, so my true MPG without waste solvent is still just 42 to 45 mpg.
I don't want to miss guide anyone when the waste solvent is enable. I just don't know how to explain it other then waste solvent is dis-able or enable.
The waste solvent so far is free. At some point and time it might not be, then i will have to associate it with a cost to run my solvent recycler to generate waste solvent and add it to to true cost of the waste solvent fuel used.
The Following 3 Users Say Thank You to pgfpro For This Useful Post:
California98Civic (07-18-2015), COcyclist (08-26-2015), deanznz (11-04-2023)
Old 08-04-2015, 12:20 PM   #269 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Been doing some EGR testing with the Talon. I have found out with cold EGR I'm not seeing any improvement in FE. In fact there is even a small decrease. I think this is do to the extreme lean burn condition I'm running.
So I'm going to try to see later this fall what it does for my emissions while on a chassis dyno with a exhaust sniffer.
The car is doing very well. I'm very pleased with the power and its efficiency.
We have had a record year with very high temperatures this Summer. This is helping with FE a ton. Our DA is around 5200'.
This winter I will be making some changes in the charge pipe configuration. I'm going to run a single pipe up inside the passenger compartment instead of underneath the car. I will need all clearance I can get for when the snow gets deep this winter.
The waste solvent unit is my favorite item on the car as of now. With these hot summer days I can even run over a 50% mix. I'm seeing different amounts of usage the engine wants base on different batches of waste solvent. I have a ton of waste solvent to test on now. My local shops have been very helpful giving me as much as I want.
Can't wait for Fall. I have been getting dehydrated from this strange hot Summer. The Talon will be much more driver friendly when it gets cooler.
jedi_sol (08-04-2015)
Old 08-04-2015, 09:35 PM   #270 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I never realized this whole time that you have an auto. Your accomplishments are even more impressive now!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
pgfpro (08-05-2015)
bio fuel, lean burn, turbo compound
