Originally Posted by aerohead
*The corporate guys do the load reduction first,with say,all synthetics,LRR tires,and aero,then try and match the gearing to get the engine to it's sweet-spot as far as BSFC goes.
*For all tires sold in the state of California,the law requires that coefficients of rolling force be provided to the consumer.If when you shop for replacement rubber,you should be able to get this info.
*You may already have all-synthetic lubes in the van.
*Aero drag reduction would provide the greatest savings on the HWY.Around town it wouldn't mean diddly-squat.You'll have to consider your needs 'n see what might fit in.NASA got to Cd 0.238 and had still left some fruit on the tree.
*Weight reduction is kinda meaningless in all-highway operation.Adding a half-ton to my CRX only cost me 2 mpg.Around town,weight savings WOULD mean $ savings.
If you can find "golf ball style" body panels with built-in dimples (or create them yourself out of clay), that will increase mpg 30-60%. Because the dimples reduce air drag(on golf balls & respectively on vehicles), this creates significant mpg improvements. Combining this with carbon-fiber panels will also decrease weight & further mpg gains.
