Old 07-20-2015, 10:31 PM   #7 (permalink)
oil pan 4
Originally Posted by jamesqf View Post
And why would filling up less often get you better mpg? (Assuming of course that you don't drive out of your way to get gas.) Even filling the tank of my Insight, rather than my usual $20 bill in the cash pump, means I'm hauling around an extra 20-30 lbs.
The theory is (on paper) that filling up less often means you carry less weight. More than likely you can calculate this difference on paper and its so small wont actually see it.
Then you get into the whole "in tank fuel pump immersion debate" where immersing the fuel pump in fuel (not letting the tank drop much below 3/4) cools the fuel pumps motor allowing it to last a lot longer.
