Originally Posted by mcrews
exactly!
When I had the Infiniti Q45, I tested running regular and high on my trips to texas. The ecu would alter the timing and reduce the mpg.
On newer cars (the Q45 was an 02) run what is recommended. THe ECU KNOWS!
The VW 1.8L turbo gas mark 4 engine saw at least 2mpg less on RUG then mid grade.
