Old 07-23-2015, 02:23 AM   #20 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by ME_Andy View Post
......Is it easy to get off if you screw up application?
while applying, i was able to lift it off before i applied heat. didn't lift it after the heat because it was where i wanted it. i used heat to remove creases.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
Daox (07-23-2015)
