Originally Posted by Longsnowsm
I like the pics you posted of the light output for the bulbs you purchased. This is a fixed High, or Low Beam bulb correct? You mentioned you are using them with a projector, but you wouldn't recommend them without the projector in a reflector housing? Thanks for your feedback and input.
It's low beam only. The stock lamps are projector housing, all I had to do was screw the new bulb in. With a reflector housing you would obviously use a bulb made for that configuration, but those have worse cutoffs since the LED is much fatter and emits light in a different pattern than a filament. The projector seems to do okay because it has a physical block off plate, but this wastes light output.
