Old 07-25-2015, 03:04 PM   #1 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
The State Doesn't Like My Cat Anymore
I went to my local smog station the other day and he started jacking up my car and looking underneath which I've never seen before for this procedure. After he was done he said that my cat is not compliant with the state. For some reason California decided to change which cats they are OK with and which ones they are not and they didn't grandfather in the invalid ones. I've had this one for multiple smog tests, but now all of a sudden it's a problem.
So... I've been reading up on cats and everywhere I read it seems that it really doesn't effect FE which cat you decide to go with, none of them will make a noticeable difference in FE.
After researching, my only question is this: does it matter if I go with a direct fit for $300 versus a universal for $150? Labor cost doesn't matter, my friend/mechanic will be doing it. I don't have an aftermarket exhaust system, everything is stock. Does one work better, provide better FE, or last longer?
Thanks!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
