Originally Posted by orengomotors
freebeard,
what do you mean by "zip-tie an airfoil to the back of the roll bar"?
the smooth wheel caps, it's a fast easy mod that i can do.
My tires have very good grip, so i reduce the contact patch to reduce rolling resistance, i run 5kg of pressure in the tires and they have a very good grip and very low friction with the road.
The round tubing is very high drag.Attaching a fairing to it can reduce it's drag significantly,even if it's foam rubber taped on with electrical or duct tape.
The contour,3rd from the bottom is the best.
