Old 08-04-2015, 01:02 PM   #11 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
One whammy! Failed mechanical inspection
planetaire: it may help to remove the the spoiler, but if you follow the link, you'll see the other Prius owner left his spoiler in place and claimed to get very good gains, even with just a basic tail design.
http://ecomodder.com/forum/showthrea...mpg-24999.html
Update: the car failed inspection. Boo.
A bushing in the front, right control arm was shot and required the arm to be replaced. And to get one of the mounting bolts out, the engine had to be lifted. Several other bolts were siezed, and hard to break free with heat/penetrating oil. Dumb design, Toyota! I had the shop do this one, and $340 later, it's legal.
And the mechanic says it'll need brakes by the time I go to sell it.
So with the impending brake and possibly exhaust work (both which I can do), I'm probably not going to make any money on this car when I sell in a year or 2, but I'll break even if I'm lucky.
After going through the car's maintenance/repair history, I saw the other control arm was replaced a few years ago. (Normal job on the left side -- doesn't require lifting the engine!). I updated the What to look for when buying a used Prius thread with a few more tips.
Now the Limo will be parked in the garage, awaiting resumption of service in the fall. I'll start it up weekly or bi-weekly to keep the batteries happy.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
planetaire (08-05-2015), Xist (08-04-2015)
