Old 08-05-2015, 04:44 PM   #37 (permalink)
phh
Wifie's car - '89 Eagle Summit DL
Originally Posted by some_other_dave View Post
89 would be non-OBD. The only way to check the codes is to pull up the front of the passenger's carpet and look at the ECU when the key is on. There is a window in it, with an LED that will blink out the codes. No long/short blinks, just count the number of blinks until it pauses.
Generally the codes are only blinked out if the check-engine light (CEL) is on.
-soD
The car is actually a Mitsubishi Mirage rebadged as an Eagle Summit, not a Honda. I was able to retrieve the trouble-codes with a voltmeter. Unfortunately the codes aren't concise enough and I still need to diagnose by hand (ugh!)
I used California98Civic's post as a rough guide and found it helpful.
Peter in Portland OR
